I'm having issues converting some AVI files that are encoded in DIVX. When I encode to MPG1 and then burn them to a VCD format using Nero, the video quality is fine, by the sizing of the video is off. It seems that the edges of the video are cut off on the TV aka you can't read the subtitles or whatever. It's as if TMPGEnc has left the ratio at 1:1 instead of converting it to NTSC 4:3 525 Lines. Has anyone run into this problem or have a suggestion on converting this properly? Let me know please. Thanks for any help![]()
Maybe you have not adjusted Video arrange method=Full screen(keep aspect ratio)?
If the DivX has proper aspect ratio to start with Source aspect ratio should be 1:1(vga).
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
