Help Required,
I want to burn multiple mpeg files into VCD format in a single cd.The size of each file is around 300MB.How can i do that without merging these two files?.I want to burn it as a seperate two tracks.Any help from any one.I have the burning software CDRWIN and for conveting the mpeg file to bin VCDIMAGER.
S.S.SREEDHAR.
Now I'm not too familiar with vcdimager but there should be nothing special about doing that, you can have 99 individual mpg's on one vcd I believe. If you want a more commercial burning program with vcd support you can download a demo copy of nero at http://www.nero.com and all you have to do is drag and drop the mpeg files into the vcd window click the write button and presto you will have your vcd.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning help
By larzhope04 in forum Authoring (DVD)Replies: 3Last Post: 27th Mar 2008, 20:58 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
