Dear Readers : I used my computer & made a dvd video movie. I used the TMPGENC standard dvd setting to render
the video, then use the Pioneer dvd-rw burner to burn it to dvd. Then I sent to replicated 500 of them. Most
of the dvd players play perfectly, both video & audio. But strangely
only the Toshiba dvd players had no audio & customers who with those
Toshiba dvd players were upset with me. I tripple check my audio
setting & it was 48000hz, 384kps. What else wrong ??? anyone out there
might know & tell me, so I won't getting crazy with it. Thanks in advance
for your time to read my post & also helps.
Dear readers: I just want to post this one , in order to tell other readers who might
encounter the same problem. I found the Toshiba dvd user manual & compared its audio spec with other brands. Toshiba dvd player can
only has 1 analog audio channel, other brands have 2 channels. When
I edited the movie with the Studio 7 & mute the original noise & unwanted
audios, then add the narrations & musics onto the 2nd channel. Guess
the smart Toshiba dvd players don't read it & caused all the problems.
Life never be easy, always something else.
Toshiba SD-4700N DVD Player
By pat8671 in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2011, 19:06 -
Toshiba SD-K770 DVD player
By diet_mountain_dew in forum Video ConversionReplies: 1Last Post: 8th Dec 2009, 14:14 -
Portable DVD player Toshiba SD-P91SKN
By fcbayma in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Sep 2009, 18:33 -
From HDV Camcorder to DVD to Play in HD DVD Toshiba HD A2 Player
By fjmr in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Jul 2008, 11:04 -
Firmware for Toshiba HD DVD player
By tmelo38 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 1st Nov 2007, 20:02
