hi , i have dilemma. i have MGI VIdeoWave and Premier 6 installed on my system. I capture from a Sony DV.
Would the quality of the captured avi change depending on what program i use? or is it solely dependent on the card (the card does the capturing and the programs only handle the resultant avi ??) ?
All captures use the same capture driver so, theoretically, the output should be the same. Any difference depends on the codec used to compress and store the AVI. If they're using the same one of those as well, you should get exactly the same thing.
Having said that, I'd still do a test run on both and compare the results. You may find one program is more CPU hungry ( or just less efficient) and you get more frame drops with one of them.
Like most other things with this video capture/convert caper, try it and see what works best for you.
Have fun,
Ian -
DV capture program COPY data from DV tape, NOT capture. This is COPYING without ANY extra compression, therefore you get EXACTLY the same results with any DV capture app.
Program to capture Move Networks Player
By tb582 in forum Video Streaming DownloadingReplies: 3Last Post: 4th Aug 2008, 17:09 -
Best Capture Program???
By Dom_Sisko in forum Capturing and VCRReplies: 2Last Post: 11th May 2008, 21:49 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 15:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Does it matter what you use to capture DV tapes to computer?
By deacea in forum Capturing and VCRReplies: 2Last Post: 18th Nov 2007, 23:20
