I have been using tmpeg for awhile now. I use premier to frameserve my
edited tv show to tmpeg for conversion. I decided that tmpeg was worth buying, so I bought the pro version. the pro version was only available in the newest version (2.54). I had preiviously been using one 2.53.
anyway, when I use the same settings as I did on the last version, my final mpg appears to flicker. im using the exact same template as I
did with 2.53
I tried using the free version of 2.54 and got the same results.
does anyone know of what could have changed between versions? or
how can I get rid of the flickering? I checked the fps, its on 29.97 like
it is suppsed too. Id just assume go back to 2.53, but I get that mpeg-2
codec expired message still. Id be happy with just finding somewhere to
get the 2.53 pro version, my serial number should still work in an older
version I think
Results 1 to 1 of 1
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 17:20 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 07:23 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 14:01 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 05:31
