  1. plz i really need this help wen i convert a svcd 2 dvdr with tmpg the stream is all jumpy the motion of ppl and camera pan is all jerky can someone plz help im now loosing my hair again just after i started 2 grow it back after the last problem i had
    Sep 2001
    N/A
    first open in virtual dub and cinvert the framesize to 352x576 now frameserve into cce and encode your dvd in that.
    Baker
    My vcd & cvdGuide
  3. im now getting an error
    MPEG filterack synchronization error
  4. sorry
    MPEG import filterack synchronization error
    Sep 2001
    N/A
    try getting dvd2svcd and setting it for avi2svcd.
    I aint sure if there is a setting to change the res but if there is selct it
    Baker
    My vcd & cvdGuide
  6. you could try putting the SVCD video onto DVDR using the method here:
    http://www.vcdhelp.com/svcddvdr.htm
    you won't have to re-encode the video, just upsample the audio.
