Is it better to be high like 192khz and 320khz or low like 96khz?
I will buy Daewoo 5800 and found it with 96khz?
please advise.
96khz is the sampling rate. It means this unit will play "DVD Audio" discs.
192khz is called "Super Audio" and is used in the more high-end recording studios. It is not a consumer format.
320khz doesn't exist.
You may be thinking of MP3 bitrates...this is not what they mean.
96khz audio is the best the recording industry offers. In theory it should sound twice as good as CD which is 44.1khz. It sounds better but, the ears can only pick up so much.
MKV and WMV audio converter
By cmars in forum Authoring (Blu-ray)Replies: 2Last Post: 31st Mar 2010, 08:09 -
DivX Converter Audio Problems
By maccool111 in forum AudioReplies: 3Last Post: 28th Mar 2010, 04:47 -
Can PS3 play 24-bit 96Khz audio on a DVD as AVCHD etc. ???
By FulciLives in forum AudioReplies: 3Last Post: 13th Sep 2009, 07:45 -
Real Audio - MP3 Converter
By soulandy in forum AudioReplies: 5Last Post: 28th Oct 2007, 17:10 -
Riverpast Audio Converter problem
By triumph2004 in forum AudioReplies: 1Last Post: 13th May 2007, 00:39
