I purchased a new HP DVD 200i writer. When I installed it, I can never get it to consistenly do a cd copy copy consistenty. I use NERO 5.3.3.8 and there are alot of error message with failure to read the vcd data from the cdrom reader. I even try to drag all the .dat file from the vcd to make a vcd mpeg-1 and it failed again. When I pulled the HP DVD writer out and inserted my
plexwriter back in, I can perform a cd copy again with any read or write error. I installed the DVD writer in both my P1 and P2 machine and the result are the same. I used Windows 2000. In both machine, I use a master and slave configuration.
Can anyone tell me what I am doing wrong.
Thanks,
Rage
Uninstall all of the lousy software HP ships with the drive.
Download Nero 5.5.8.2 and install that.cheers!
Samsung SH-S243D DVD writer - CD media burn quality
By onland in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Feb 2012, 23:52 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVD Lab Pro 1.6: Links in menus get blue under fresh Windows installation
By Paker in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2011, 13:54 -
New DVD writer... Burn process failed at 2x (2,770 KB/s)
By planetx in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Feb 2008, 16:40 -
My HP DVD Writer 840x Wont Burn !?
By ticotaz in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Jan 2008, 06:23
