  1. Hi there,
    is it possible to interupt and conversion process in TMPG Encoder and finish it later?
    Thanks in advance
    Best Regards
    Schrulli
  2. AFAIK, NO
  3. You can only stop TMPG using CPU by going to Help >> About.
  4. hey WarpEnterprises, thanks for that, I didnt know and often thought such a feature would be useful!.
    Thanks again
  5. Just hit the stop button, but don't answer the yes or no pop up question. That will pause it. I do that a good bit when I need the computer power back, halfway thru an encode.
