Can I edit an Avi in VDub then Frameserve it without saving it first.
The Avi is a capture which is split into the max 2 gig segments (due to Fat32 etc). So if I save the file after editing, will it still be in it's max 2 gig segments or can it only save as a complete avi ?
Thanks.
Tone.
Yes. You can certainly do that. And that is my preferred way of using Virtualdub.
As far as saving your captured AVI, I dont know. I tried saving a few months ago when I first started using it. It was taking too long, so I aborted the save.
As a side note, when you capture with Virtualdub, the file is saved on your hard drive (in your case various 2 GB segements). All you have to do is find the captured AVI file and make sure additional segments box is checked.....and walla.....you see your video. But you probably knew this.
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 18:13 -
VFW ffdshow Settings to Edit flv in Vdub
By kaskaļ in forum Newbie / General discussionsReplies: 15Last Post: 1st Jun 2011, 11:40 -
Edit Avi: VDub / VDubMod / Nandub
By Rinsin in forum EditingReplies: 11Last Post: 1st Mar 2010, 17:33 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
Edit M2TS and saving it as M2TS
By Andreas Furumo in forum Video ConversionReplies: 3Last Post: 28th Aug 2009, 14:07
