Just wanted to know if a psx NOT a ps1 can play a vcd.
i have also herd that there was an avi or mpg player that u burned onto a cd with the avi or mpg, i seen it on many sites but all had broken links!
PLEASE help soon!
Results 1 to 13 of 13
The PSX (big old model) had an add-on that you would plug into the back and would decode VCDs.
actually all psx and ps1 can play vcd's, you just need the vcd add-on.
for the psx's its a vcd card, similar to a gameshark only bigger. (this is external)
for ps1, its like a modchip monted ontu a board (fits internally)
for ps2, its a boot disc similar to the one doe the dreamcast although this one plays good : )
The AVI or MPEG player you talking about is called GYPLAY and it works on dreamcast. Playing movies with this gives you great quality like a DVD playr or ps2 would give you. The only problem burning a movie like this is that it can only be played on a dreamcast and pc.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Great Quality? Are you being sarcastic? -
No. GYPLAY has really great qaulity. the VCD player for Dreamcast succz tho, big time. if GYPLAY could play vcd's it would be great but it can't
you have to put the dat/mpeg on a cd with gyplay.
ok this is really starting to get old now. I have all the vcd boot disc and hardware needed for evrey system. Yes that includes the PSX. and it succz. that's it plain and simple, don't bother with it, can't get more staight forward then that.
On 2001-08-03 21:40:17, SiNXation wrote:
No. GYPLAY has really great qaulity. the VCD player for Dreamcast succz tho, big time. if GYPLAY could play vcd's it would be great but it can'tyou have to put the dat/mpeg on a cd with gyplay.
Are your videos encoded at a bitrate around 800kb/sec? The DC is known not to be able to go above that. It gets choppy on anything higher. -
the vcd's are standard format. Yeah it not as choppy just out of sync mostly.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
LG DV 390H - unable to play VCD
By rach1234 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 31st Aug 2010, 08:25 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 05:14 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15 -
ACCURIAN APD-3955 play VCD?
By UltraVCDDVD in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2008, 12:48
