Hi everybody. Please give any advice.
Whule exporting my video (timeline) in Premiere 6 back to the mini DV tape ( Camcorder is JVC GR DVL 300)every 2 minute or so the frame freezes ( I think its droped frame) for a second. Settings seem correct to me which are as followes
Video
mode Microsoft DV AVI
Compressor Microsoft DV (NTSC)
Frame size 720 X 480
Frame Rate 29.97 FPS
Dept Millions
Quality 100 %
Aspect Ratio D1/DV NTSC (0.9)
AUDIO
Sample rate 48000 Hz
Format 16 bit Stereo
Compressor uncompressed
Rendering is Lower Fields first
Ant suggestions !!!!!!
hey i got a similar problem when trying to exoprt to my cannon zr mc 45. i tried using the export to tape and also by just playing it on the timeline. i also tried exoprting the video as one solid video instead of project file with cut up videos. everytime i still had freezy video about every 1:30 secs. i dont think it is anything related to my video camera. i also tried using different minidv tapes. i think it may have something to do with my ieee 1394 cable. any ideas whats going on?
I've not experienced this as I have never output to tape but I was wondering if you rendered the transitions & effects, etc. before outputting. I'm assuming the tape must run at a certain speed and if Premiere is rendering during output it might not be able to keep up with the speed of the tape ??
If you have pre-rendered then please ignore me
Premiere 6 had a lot of bugs when it came to DV .. upgrading to 6.5 seems to solve most of the problems (but you have to uninstall 6 completly first) ..
more info found on the adobe premiere forum
Premiere CS4 lossless exporting
By timwizard in forum EditingReplies: 7Last Post: 16th Feb 2010, 09:49 -
When exporting out of Premiere...
By bsuska in forum Video ConversionReplies: 20Last Post: 4th Jan 2010, 17:22 -
Render before Exporting in Premiere Pro
By newsphotog in forum EditingReplies: 1Last Post: 29th Sep 2009, 10:39 -
Exporting movie from Premiere Pro 2
By daninor in forum Video ConversionReplies: 16Last Post: 18th Apr 2009, 16:54 -
Problem exporting xvid/divx with Premiere CS4
By moogleii in forum EditingReplies: 2Last Post: 23rd Mar 2009, 19:18
