  1. I want to know how i can do all of the extraction from the DVD on one computer and then do all the processing on another computer.
    My slowest computer is the one with the DVD-Rom Drive. It is networked to my fast computer which i would like to do all of the processing. I don't mind it taking a while to copy over the files (i know they'll be large).
    Any advice would be great.
  2. open dvd2svcd on your slow computer, activate ripping (in the rip tab) and start dvd2svcd. then, while it's ripping your dvd, close dvd2svcd. it will finish copying and then close. then copy the files on your fast computer and start dvd2svcd. deactivate ripping (in the rip tab), open your copied ifo files and continue as normal.
    if your using windows on both machines, you could also try to share the ripped files on the slow computer (using windows), and the open them on the fast computer.
    hope this helps
    pagan
  3. Thanks, i'll try that tonight, i'm new to all of this
