so far i have tried 3 capture cards on 2 different mobos. Both mobos have the VIA chipset. The problem is when i try to capture some video my pc completely locks up. My current capture card is the ATI tv wonder ve, but i have tries a hauppage wintv and a pinnacle rave. So i reakon its my mobo which is causing this problem. Can any body recommend one to me. It has to be socket A.Thanx in advance
I use the win tv / dbx(model 401).....my mobo has the SIS chipset and everything has worked perfect from day 1 of installing cap card...my mobo is the ECS K7S5A...good luck!
I have 2 different VIA chipset motherboards, both with ATI video capture cards(AIW 128 and 7500) and have no problems capturing with either motherboard. Make sure you have done the following and it should work for you.
1. Load and run the latest VIA 4in1 drivers.
2. Make sure nothing else uses the same IRQ as the ATI card.
3. Defrag your drive.
4. Turn off all other programs when capturing(check whats running in the background)
5. Check your BIOS settings.
6. Load and run the latest VIA 4in1 drivers.
Maybe a MOBO issue??
By SE14man in forum ComputerReplies: 18Last Post: 13th Dec 2011, 14:55 -
Dead Mobo?
By Poppa_Meth in forum ComputerReplies: 14Last Post: 20th Sep 2010, 21:17 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 11:49 -
mobo's with HDMI
By Xylob the Destroyer in forum ComputerReplies: 12Last Post: 9th Feb 2008, 13:12 -
MOBO for video editing ??
By Dash1 in forum ComputerReplies: 9Last Post: 9th Dec 2007, 12:15
