  1. ---Ok, Some of you say that is best to use virtual dub to help me convert avi's to mpegs and such. Somethig about making a wav first then add it in when you get the video input set. Is this right? How does a newbee like me use virtual dub. Also when I try to open a avi that is a asf file the program says it won't open this file because of restrictions. How do I get around this.
  2. if you want to know you should check out the HOW TO colume to the left of your screen its has detailed info on how to use vdub, tmpgenc etc.
