I have a question, will Premier let me export a 1 hr show into VCD Mpeg ( panasonic for example ) after I cut out the commercials? My friend is supposed to give me the Premier since he does not like it.
I know that VirtualDub can cut the film strip too but I want to be able to add some start screens too
Thanx
"Computers are stupid, but they are capable of being stupid one million times per second"
If you have a plugin that allows Premiere to encode a VCD then sure, you should easily be able to output whatever you've edited.
I use TMPEGenc to cut out the commericals by setting the source range to cover each act minus commercials. Then I put each segment into a batch process and merge them all together afterwards with mpg tools.
For an hour long show, you'll usually end up with five 7 minute segments.
I'm guessing this is how most people do it.
Mojo
Trying to record ONLY commercials
By Ch3rryC0ke in forum DVB / IPTVReplies: 7Last Post: 12th Sep 2011, 13:21 -
Editing Commercials
By Jacks_Daddy07 in forum EditingReplies: 2Last Post: 19th Oct 2010, 00:09 -
Help - Need to remove commercials & other bits & pieces from TV show
By jcikal in forum EditingReplies: 1Last Post: 7th May 2010, 16:36 -
Recorded my 1st TV show from Win 7 WMC! hnow how do I edit commercials.
By peggypwr1 in forum Newbie / General discussionsReplies: 7Last Post: 2nd May 2010, 07:13 -
How to edit/Remove Commercials from .ts files captured by ProgDVB?
By MounaLafi in forum DVB / IPTVReplies: 4Last Post: 2nd Oct 2009, 07:41
