I'm planning to get a new system and want to get started, but I've read so much I'm thoroughly confused.
To transfer VHS tapes untimately to DVD, which method of getting the tape into the computer is better: via an ATI AIW for example as an AVI file with Virtual Dub, OR digitalizing it with say a Dazzle Hollywood Bridge or the Canopus. The captures would be long (1 hr. plus) so I worry about sync problems. Then I would encode with say TMPG Enc. There would be no fancy editing, just cutting.
Some of the tapes are getting bad, and most were recorded in SLP to begin with so the quality was never the best.
If the capture card is recommended, please recommend a card. If the dv
conversion method is prefered, please advise if Dazzle or Canopous is
prefered for quality.
Thanks in advance. JB
Get the canopus AVDC-100 or a digital camera with analog IN
The reviews i have read on the DV bridge say it does have sync problems.
I did the analog capture thing for a while, but found it to frustrating.
....dropped frames , sync issues, LARGE files ...
I finally got a cannon zr40 camera with A/D converter and now use it to pass through my VHS and capture in DV format.
Happy now ... smaller files , less time pi$$ing around setting up for capture, no sync problems or frame drops.
IF .... IF you have a fast/large drive setup then a cheap $50 card might be worthwhile if you have time to waste.
my 2cents -
The Canopus is quite good. I've done captures as long as 2hrs from tape and antenna passed through the VCR and the only time I dropped a frame was when I once tried to start up another program while capturing, the audio and video never get out of sync and although the files are large (2GB for every 10 minutes) that's the price you pay for getting the quality.
This should solve most ( all? ) of your sync problems and might even clean up the picture somewhat
Canon hv20, 24p hdv, and recommended capture method?
By joshcali in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 4th Mar 2012, 18:28 -
Which video capture method would you recommend
By rysktkr in forum Capturing and VCRReplies: 2Last Post: 10th Jan 2012, 14:45 -
Analog capture poll
By goggy59 in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2009, 19:28 -
Method of VHS Capture to DVD
By robjv1 in forum RestorationReplies: 15Last Post: 28th Nov 2007, 09:00 -
Best capture card and method for VHS to DiVX?
By Vantage in forum Capturing and VCRReplies: 9Last Post: 4th Aug 2007, 14:11
