ok i have two dvd compliant mpeg-2 dvd rips, i trid merging them with TMPGenc but the audio got way aout of snyc on the second half of the movie. when played each on their own the audio is perfectly in sync. im wondering if i import both clips into a program, such as dvd moviefactory for example, will it play seemlessly? if no, is there a way i can make it so? an even better answer would be how to put these two mpegs together properly so that the audio stays in sync...thanks!
Results 1 to 1 of 1
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
compare movies, find insertions in one movie relative to another movie
By beroal in forum Newbie / General discussionsReplies: 0Last Post: 18th Jan 2012, 23:11 -
HDTV makes DVD movie look "less" like a movie?
By breakchange in forum DVB / IPTVReplies: 73Last Post: 6th Oct 2011, 09:28 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 11:33
