My friend and i burned a vcd off of his computer using nero.....then we played it in my dvd player....and it worked fine. But When i try to burn a vcd from my computer(using nero) it wont work in my dvd player...why is that?![]()
please help
Matt![]()
Very vague on the description there. There could be a million different things that could cause that. Maybe some computer specs of the two systems would help. Did you use the exact same cd media? Burn speed the same? Were both standard VCD's with the same bitrate?
sorry the description was a little vague.....um i have tried to burn several vcds....it says they work, but when i put them into my dvd player it wont work. what could be the problem? the settings on my nero were the same as his settings but it still wont read it on the dvd player.
What is the make and model of your DVD player? And are you using CD/R or CD/RW's?
i have a phillips dv910, that will play vcds, and i'am currently using cd-r's
any suggestions? -
Try a cd-rw. My dvd player sometimes hangs on cd-r's, but does much better on cd-rw's. Plus if it doesn't work you can always erase it.
are you using different types of discs than the one your friend burned on his comp ???
DVD/BD player that supports MP4 file playback?
By RogerTango in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Sep 2011, 01:09 -
DVD player supports .vob format
By desertoil in forum DVD & Blu-ray PlayersReplies: 13Last Post: 19th Mar 2009, 20:00 -
Panasonic DMRES45V DVD remote doesn't work correctly
By cep8719 in forum Newbie / General discussionsReplies: 2Last Post: 27th May 2008, 11:00 -
WinDVD7 wont play PAL dvd with mpeg audio correctly ?
By deejay.2001 in forum Software PlayingReplies: 2Last Post: 26th Apr 2008, 14:57 -
DVD player that supports GMC?
By perdomot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Nov 2007, 17:38
