Hi All,
Well I am trying, unsuccessfully, to encode my avi files @ 23.976 fps using Nero. I have used other softwares, the Panasonic encoder keeps crashing or gives me audio sync errors, and Tmpeg gives me audio sync errors. So far only using Nero for encoding avi's and burning straight to disc is stable and gives me no audio sync issues. Plus it is fast and hassle free. Problem is all my avis are in 23.9 76 fps and Nero only gives me the option to encode either in 25fps PAL or 29 fps NTSC, both of which are causing jerky images.
So the question is, is there any way we can encode in 23.976 fps using nero burning rom V 5.5.8.2
Is there some hidden setting, or some registry value that I can toggle to get round this issue?
I would really appreciate any help at all in this matter.
Thanks,
R
