i am running windows 2000 and nero 5.5.2.4
my scsi cd-rom drives become locked all the time and are unaccessible through explorer.
however, i can run "cd-info" under nero and see the disc there. i can also copy a disc that is put into a locked drive.
what gives?
THIS IS HARDCORE
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=51288&forum=1
This doesn't help I just thought u might like to read the last few posts tho
<font size=-1>[ This Message was edited by: rayjr13 on 2001-08-02 06:24:23 ]</font> -
thanks.... but it really isn't a matter of the disc not ejecting.
when i select a drive in windows explorer, it opens that dialog box asking me to put a cd in the drive.
what gives?
THIS IS HARDCORE -
i'm not sure if nero does this as well, but i remember that when i used to use cdrwin, it would lock all my cdrom drives while the program was still open. [actually it might have been nero at that]. anyways, try closing nero and then checking explorer.
i have tried doing that... the only fix is to boot the pc with the desired disc in one of the scsi drives.
my ide dvd-rom has no issues whatsoever
thanks
THIS IS HARDCORE -
ive had this problem with windows 2000 myself, i found a lot of programs and software were not compatible with that operating system, i have now gone back to windows ME, and everything is fine again. hope this helps
stu252
Locked Folder
By dfisher052 in forum ComputerReplies: 3Last Post: 7th Sep 2011, 17:39 -
Connecting the DDR and CD-Rom drives
By hellfire45 in forum ComputerReplies: 17Last Post: 4th Oct 2010, 01:57 -
locked post
By jonnyD in forum SubtitleReplies: 1Last Post: 2nd Oct 2007, 10:34 -
Locked out of my router!
By Xylob the Destroyer in forum ComputerReplies: 4Last Post: 14th Sep 2007, 10:28 -
Find Firmware for CD/DVD Rom drives?
By Ghtpua in forum ComputerReplies: 8Last Post: 26th Aug 2007, 14:27
