Hey All,
I heard that a SVCD with Dolby Digital isn't possible, i can only make Dolby Surround SVCD's but check this link
http://www.turbodog.org/evans/covers/ViD/The_Fast_and_the_Furious(back)-ViD.jpg
It says "Dolby Digital"!! How is this possible!?
Please tell me!
Greetings, Codex
I know,
but i saw more of this images. I don't know if it is just a DVD cover rip or something like that but i just want to have it on my SVCd's if it is possible. -
No, it is not possible. SVCD does allow for multichannel MPEG audio. This would allow for 5 seperate analog channels of audio. however, you would need a linux based program to make such an audio stream. Then you weould need one 2% of receivers on the market that would actually deocde the multichannel mpeg properly into the different channels instead of decoding it down to Dolby Pro Logic like the all the rest of the receivers out there do.
Thanks,
Know i use Dolby Surround in my SVCD's, but some small sounds (like a falling glass) sounds much louder on a stereo system. how is this possible?
and should i encode to Stereo 224 Kbps or to Dolby surround? 224 Kbps?
In my opinion the Dolby Surround quality is not that good.
Greetings,
Codex -
well first you can not encode into Dolby Pro Logic Surround. Dolby Surround is strictly a decoding procedure that is done on a stereo channel. It takes a 2 channel stereo signal and derives the rest of the information for other speakers from it. For my personal tastes, 224 kbps is overkill for SVCD, I usually drop mine down to as low as 160 is as far as I will go. Some other poeple have posted that go as low as 128.
If you are downmixing 5.1 to Dolby Surround, my advice is to turn off dynamic range compression. It can result in odd volumes on the resultant VCD.
Normalisation is probably okay but I personally just suggest that you turn up the volume of your speakers...
Regards.Michael Tam
w: Morsels of Evidence
Dolby Digital 5.1 track?
By dstrahan in forum DVD RippingReplies: 1Last Post: 24th Jul 2011, 23:48 -
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
Dolby Digital 5.1-ch vs. Dolby Digital 2-ch
By coody in forum DVD RippingReplies: 6Last Post: 21st Jun 2008, 15:35 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54
