  1. hey,
    im trying head this svcd (spiderman) so it will think the svcd is a vcd on my dvd plya, it gets a bufferunder flow i close all the programs i can on my program tray im using tmpg enc here is the link to the site on wat im trying 2 to do : http://www.geocities.com/newestmoviesencode/dvdvcd
    Thank You 4 any help Faruq
  2. as I already posted, this buffer overflow occured to me each time I tweaked a sound file and multiplex it with the premium video file....
    Even, no out-of-sync occured after so file should be ok......
    My explanation is that because the new sound file is smaller than the original one, something in the program/file could sounds "wrong" but is in fact "ok"..
    "OO"
    P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
  3. [quote="" but is in fact "ok"..
    "OO"[/quote]
    I have the same problem with spiderman. It quits everytime with the message buffer underrun. The thing is the synchronisation is ok, but the vcd stops. So the result is that i have a cd where everything is ok but the last 10 minutes of it are gone. So it;s stops decoding after the error message leaving you with half the movie.
    D you please now how to solve this?
  4. well, first, I am mostly working with premium mpg files... Divx/avi are quite "touchy" because encoding bitrates for sounds and even video are always differents..... And the way .avi files are encoded is always harder for a tweak... and then, for sync or any other "after job" situations....
    Please tell me (or us) what is your procedure exactly...... I guess you started with the TMD Divx encoding but after that....... every file could be a quite different job......
    Hope it helps for now.......
    "OO"
