...at least it is for me, and i have a pretty fast computer.
Is it my TMPGEnc settings? (I used the all in one conversion guide on vcdhelp.com)
Is it TMPGEnc?
Should I use a different program?
Am I just too impatient?
Basically, I have to sit there while it converts the whole movie in real time. In other words, a two hour movie takes two hours to convert...
Any advice?
Oh yeah...and VCDEasy won't recognize my burner!![]()
Results 1 to 10 of 10
converting a movie to mpeg in real time (even VCD spec) is pretty good going by anybodys standards!!!
Most people work on the idea of conversions running overnight or whislt out at work. Think yourself VERY lucky!
Oh and yes, you are too impatient. -
I wonder what system you are using. I hardly encounter any system to encode using TMPGEnc realtime. I recently build a Athlon XP 1800+ system and the encoding time is still 5-10X the video time. Appreciate if you can enlighten.
BTW,
I'm using:
Abit KR7A-RAID
XP 1800+
512MB PC2100
120G WD Special Edition 8M Cache HDD
Windows2000 -
Originally Posted by p5mmr9
It takes me,
12+++ hrs to do a vcd @ 1800btrate 352x240 no filters....
24+++ hrs svcd @vbr/cq 1 pass 480x480 no filters.....
on a PII 400, 256mb ram.... I live with it.... movies turn out fine though. -
p5mmr9. Yes you are impatient, real time encoding is fine for current technology and you appear to have plenty o horsepower. As for sitting there for two hours. Go outside and get some fresh(ish) air
I'm building systems for commercial use and 1 minute can make a lots of difference. Any other good system spec suggestions? Dual processor systems are good but too pricey.
Originally Posted by vcdfreak
1. Price point (your target budget for the system cost at your end)
2. What you will build the system to do
3. How fast it must do it
(the crystal ball is a little cloudy; you know, it never has worked quite right).As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
If I'm not using any filters and leave the motion estimate on 'normal,' a regular VCD usually encodes in close to real time (maybe 1/3rd longer).
I'm using a 1.2 gig Athlon and a gig of RAM.
Now, when encoding an SVCD with noise reduction and 2 pass VBR, a 44 minute TV show can take 16 hours!
Why, oh why are we cursed with this silly hobby?!
Mojo -
haha, i know the feeling! you're certain that it's not worth the time and effort, afterall you could just use a vhs tape, but we try anyway......
Help : FLV to AVI Slow Conversion
By d3ck in forum Video ConversionReplies: 9Last Post: 22nd Jun 2011, 04:55 -
slow motion by interlaced to progressive conversion?
By menczel in forum Video ConversionReplies: 9Last Post: 24th Apr 2011, 10:39 -
VOB2MPG Pro preview not working & conversion slow
By MDJH in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 22nd Sep 2009, 14:01 -
Slow video progression rate after conversion
By mohit in forum Video ConversionReplies: 2Last Post: 8th Feb 2009, 11:19 -
Video conversion suddenly became too slow.
By syedmahm in forum Video ConversionReplies: 6Last Post: 28th Aug 2008, 08:37
