I have a VCD which when I play hanged and there are many frame drops. Is there any way I can repair it.
Thanks in advance.
What files? What did you use to encode? What NLE are u using?
What did u use to burn the VCD?
and on and on......
Maybe. Depends on what exactly is wrong. If you can copy the dat to your HD, then run it through VCDGear using dat>>mpg with fix errors selected. Then burn as VCD again using Nero or alternative.
I did copy DAT file to c drive and use VCDGear, I had no problem converting it to mpg but when I play there are frame drops at end and some time media player hanged. Is there any utility I can fix it
I would say you have done all you can. Instead of using VCDgear you could use TMPGenc's mpeg tools. Copy the dat to your HD. Change the file extension to mpg. Demultiplex it, and then multiplex it. Burn with Nero. Chances are high you will still get the same reult, though!
Try MPEG Repair section. I've had some MPEGs hang on me (like they don't even play), and that kinda fixes it sometimes.
/\/\ars /\/\ayhem -
Have anybody try to use the utility "FIXMPG1.exe". When I try this on command prompt
c:\fixmpg1 mpegfile
it out put to files
mpegfile.mp2
and
agd.mpv
Do basically it is spliting audio and video, but according to the descripation it sound fix broken mpeg. Does any one know correct command to fix mpg using this utility
http://www.geocities.com/SiliconValley/4942/svcd.html
I not able to run this utility because there is not much information.
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
I need PAL format help...
By jenn00_v in forum Newbie / General discussionsReplies: 15Last Post: 26th May 2009, 16:29 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2007, 23:26 -
Actual format PAL??
By KingBongo in forum ffmpegX general discussionReplies: 5Last Post: 11th Jun 2007, 06:29 -
using pal material to work in an ntsc format
By rapidondamove in forum MacReplies: 2Last Post: 7th Jun 2007, 16:22
