My input is a movie AVI file from the Internet. I'm using
TMPGEnc with all defaults. I try to convert my AVI to MPEG-1.
So, my conversion is done in about 30 minutes but I have no video at all
only sound. I downloaded all latest version of TMPGEnc 2.54 with plug-in
and Divx 5.02. Still TMPGEnc produces MPEG file that has just sound.
Yes, I did check an appropriate box(video + sound).
Any idea?
One idea, use the search function at the top of the page, it is very useful and you will almost certainly find the help you need.
Just go here and read haow to solve the problem!
http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860
good luck! -
I had this problem before. I solved it by splitting the audio form teh AVI using Virtual Dub. Just make sure your conversion settings are OK. It worked fine for me!
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
