Heho,
i want to convert a divx film, 690mb(1:48) in svcd. but tmpgenc tells me, that it will be over 4000mb. what the.... . Usually the files amount to 1600mb. what is the reason for that???
thanx..
nicmare
A little more info would help, such as length of movie, resoltuion of source avi, Tmpgenc template selected and any changes to defaults would be a good start.
Try saving your audio file with vdub as a .wav file and use this new file in Tmpg!Sounds to me your audio is in vbr
how can i notice the details of my avi file??? the new divx player doesnt have such a tool. and i said the movie dures 1:45 but the forum made a smilie lol....
Nicmare
//EDIT: i checked out some details with darim tool:
resolution: 640x352, 16bits/pixel
fps: 25
audio: no audio
duration: 1:48
It seems to be a problem of the sound, because tmpgenc shows me a message because there a probs with audio...
so now at the moment i try the darim conveter(only video) and i will try to split the sound from the videosource...
//EDIT: ok, the prob was the sound...i will check it out...
but thx anyway
ANOTHER BIG PROBLEM:
tmpgenc is very bugy and it crashs every time when i want to encode a divx film...but sometimes it do not. what is the reason of crashing? i mean its encoding perfectly for 10 minutes or 1 hour and suddenly it crashes!
ps: my english is bad, i know, i am no englishguy hehe
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
