Everything i've tried! Extracting the .WAV file, every acceptable bitrate, with subtitles, without subtitles but i can't get the audio synchronised with the video... Has somebody experienced the same problem or, more important, is there anybody with a solution?
Yup, know what you are talking about, I had the same problem.
In TMPGEnc (I assume you are using it), under Environment Settings/VPAFI settings, right click on the directshow filter and promote it until its priority reads 4 or 5 .
This improves the ability of TMPGEnc to read AVI files in much the same way your media player does. It should solve your synch problems - I know it worked for me.
AVI with AAC audio to AVI with MP3 audio
By Neroon in forum Video ConversionReplies: 6Last Post: 30th Jun 2010, 08:15 -
VCD Dual-Audio to AVI
By amadeira in forum Video ConversionReplies: 10Last Post: 12th Oct 2008, 11:10 -
Dual audio AVI to singl audio AVI.
By Benhermies in forum EditingReplies: 8Last Post: 20th Aug 2008, 20:44 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
