I am creating a DVD home movie using Ulead's DVD Workshop .
But I couldn't get the Motion Menu to work. Under the MENU Tab, I can enable or select "Motion Menu" and give it a 5 second duration. But I couldn't enable or select "Motion Background". It is grayed out.
Am I missing something here? Any help is very much appreciated.
Thanks,
Joey
Sounds like you using the trial version which has these limitations. Obtaining the full version will solve your problems.
joeydlc, if you are using the trial version this may not work... you have to drag and drop your background video on the menu before you will be able to enable background motion.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Editing and replacing a motion menu problem
By kpic in forum Authoring (DVD)Replies: 4Last Post: 5th Aug 2010, 17:11 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Motion menu thumbs in DVD Workshop 2
By milway in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2008, 07:12 -
Editing Motion DVD Menu
By gallardo in forum Authoring (DVD)Replies: 5Last Post: 6th Nov 2007, 21:12
