  1. i a'm sorry to bother all of u again, but i think i have a problem.
    i uesd winsubmux on an mpeg file, and i didnt burn it yet.
    the file is still just a mpeg file.
    can i use windvd to watch the file with the selectable file
    or i need to burn it on a cd, like in nero 5.5 or other program
    to able to see the result ?
    btw, i burned the test svcd pal cd, and in windvd i able to chose
    betwin the 2 audio file, but there wasn't any subtittle to chose.
    so i didnt anderstand if i cant see subtittle, or the fact that i can chose
    betwin the 2 audio file i will be able to chose difrent subtittle ?
    10x in advance.
    Aug 2001
    Finland
    Selectable subtitles are not supported by WinDVD or any other software. You have to burn the Cd and test the subtitles on your stand-alone player.
  3. ok.
    so i need to burn the file.
    but my file is 1.5 giga after i used winsubmux, so the subtittle
    are inside the mpeg file.
    if i split it, the sub will be ok, or i need to do something else ?
    10x.
