What's the best card to capture VCR/TiVo recordings with? I'd like MPEG2 format, and I assume you can't use the coaxial output without having a tuner to decode the signal, correct?
So, I either need a capture card with a tuner that can get the signal through coax and capture in MPEG2 or I need to run a composite cable about 50 feet. Is it possible to run the signal that far?
I tried the Creative Digital VCR, works great, but only by itself. I couldn't find any info on how to use it outside it's own software or to use it's files so that card is going back to Fry's...
Any help greatly appreciated.
I would suggest an ATI Radeon All In Wonder. I'm using one now, and love it. Ive just started capping in MPEG2 myself. (i just learned a trick to get them to play on my dvd player.) And its got composite in, along with red/yellow/white rca in and svideo in. Svideo & RCA are on a purple breakout box and they also work as output. And its got a built in tv decoder, although if youre just doing vcr/tivo, you dont really need it. I cap stuff from my tivo all the time with the radeon, and they come out great.
Excellent! Thanks for the reply!
How are you sending the TiVo signal? Thru coax, composite or the RCA lines? My problem is the TiVo is in the living room, PC in the office, it's about a 50 foot run and neither unit is available to move closer to the other. Also what software are you using to capture the TiVo? I can't find any firm info on the length one can run RCA lines without losing signal integrity.
Thanks again!!!
Hauppauge 2250 Tuner Card Aborts Recordings
By rixware in forum Capturing and VCRReplies: 8Last Post: 30th Jul 2012, 13:14 -
Problem capturing sky digibox recordings
By scamperoo in forum Capturing and VCRReplies: 9Last Post: 19th Oct 2009, 10:32 -
Can I edit Tivo recordings?
By Clement in forum MacReplies: 8Last Post: 7th Jul 2009, 16:12 -
useing a tivo type unit to record from a vcr
By 2boot in forum RestorationReplies: 0Last Post: 20th Feb 2008, 19:36 -
Is a HDMI capture card or firewire better for transferring dvr recordings?
By yoda313 in forum Capturing and VCRReplies: 0Last Post: 9th Dec 2007, 14:42
