  1. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    When I list all the posts of a certain author it states that I created all the posts. Kinda weird.
    dp you mean this user search?
    http://forum.vcdhelp.com/search.php?search_author=adam&showresults=posts
    and it says that you have created all that posts or what?
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Actually yeah. It says the user's name Authored each post. I was looking at mine at the time so that's why it said I authored each one. Should it be like that or is there a problem somewhere?
    that one lists your posts and not topics...and then it should say you as author even though you didn't author just that topic.
