  1. I am using a All-In-Wonder 128 Pro with MMC 7.6. I am recording a TV signal at 720x480 - MPeg-2. It captures fine and I use DVD2AVI to create a set of "masters" that I convert for VCD, Hi-Res (720x480), and SVCD.
    When using TMPGEnc to create each format, the Hi-Res, and VCD have the same level of brightness as the origional; however the SVCD is significantly "Brighter", to the point of losing detail.
    Since I am using the same "master" to create each version, why does this happen only to SVCDs. I've tried both the built in SVCD template as well as KingVipers SVCD Template.
    Nov 2001
    Sweet Home Alabama USA
    I have found that using DVD2AVI video becomes "washed out" if I use the Video/YUV->RGB setting at TV Scale. Try PC Scale on your SVCD, gives me a much better picture on both my TV and PC.
