  1. I am trying to capture 8mm tape to VCD / SVCD and noticed that the audio is in synch if I capture in mpeg1 but is out of synch if I capture in mpeg2.
    Any ideas out there?
    Intel 1.9Ghz
    Intel MB
    Radeon AIW 32MB DDR
    Sound Blaster Live Value!
    40GB ATA 100 7,200 RPM.
    265MB RDRAM
    Thanks in advance,
    Dr.D
  2. What is your player for the MPEG2 file? Try a different player.
    Are you using MMC 7.5 or 7.6? I am using MMC7.6 and I have done a lot of 8mm tape captures and had no problem for Video Audio sync.
