    Nov 2000
    I am trying to find something out. I have a problem with VirtualDub that started about 3 weeks ago, when I go to encode the movie into Divx from Mpeg ( captured in MMC 7.6 ) it will start encoding for about 18-21 min & then it gets stuck ( I have the dump that VirtualDub gives you ).
    I am using Divx 5.0.1 & Radium MP3 codec for audio ( I do the appropriate bit rate for the Divx & 128kb for the audio )
    So I thought it had something to do with the Divx 3.11 I installed together with Divx 5, then however I had a Hard Drive problem so I have put new HD in & installed WindowsXP Pro etc all from scratch, installed the Divx, installed the Radium MP3 codec & installed VirtualDub, I started the encode & the same thing happens. New everything & it still happens. I am stumped. I do not know what it can be. Please help me.
    I had this working ( same setup ) for about 8 months with out any problems ( I may have had an older version of VirtualDub )
    Thanx.
    Here is the CrashDump file
  2. VirtualDub work with AVI files not MPEG for conversion MPEG to DIVx use FlaskMPEG.
    With Kind regards Yury.
    Nov 2000
    Yury, thank you for your suggestion ( I always thought that Flask was used to conver DVDs to AVI for the most part )
    I will give it a try, however, I have used the VirtualDub to convert MPEG to AVI (Divx) & it worked with out any problems.
    I am not sure where the above described problem comes from.
    I got the tutorial from here on how to convert MPEG to AVI (Divx) using VirtualDub.
    Thank you however, I will try what you suggested
    "Computers are stupid, but they are capable of being stupid one million times per second"
  4. Sorry I can offer any help.
    I have a simmilar problem if not exactly the same problem.
    No matter what I do it freezes for me when I get to frame 9995.
