  1. I have a DVD, that will not play in my DVD drive on my computer (it plays fine in my home DVD player).
    I have tried to decyrpt it with multiple programs (DVD Decrypter was the last I tried), none of which work.
    After decrypting the DVD, when I go to play it, the first 3-4 minutes of the move appear to be fine. When the Title of the movie is displayed, it will play a few seconds of the film, display the title in English, then play the same few seconds of the film again and display the title in Spanish, and I loose audio when this happens.
    Any way to get around this?
    Thanks,
    Flagg
    Jun 2001
    England
    When decrypting the video are you using file mode or movie mode? (Sorry these are SmartRipper terms, I have never had a need to use anything else)
    Many DVDs are multi-angle and will result in the effects you describe when ripped incorrectly.
  3. I tried to use smartripper, but could not get it to work properly on XP. I finally got a program called decrypter to work, I had to choose video angle 1, and it worked great.
    Dave B, thanks for the input, you put me on the right track.
    Thanks,
    Flagg
