i just got a new All In Wonder Radeon 7500. it came with the Remore Wonder ( RF remore control ) after installing video card and remore, my vcr upstairs started acting funny. It would start playing for about 5 seconds. Then the vcr would shut off. When i turned it back on the tape ejected. It ate one tape. I couldn't figure it out. Then i realized that the vcr screwed up the night i installed the remote. I unplugged the USB reciever and took the batteries out of the remote. Teh vcr is playing just like it should. I don't know what could've caused this because the vcd uses a infrared remote and the computer remote uses radio frequency. Any ideas? Thats the only thing i can thing wouldv'e cause the problem.
Bob
Honestly it sounds like you had a bad tape in it or it could have been that you or someone else put it on a timer to record something.
LG RH-7500 Optical Drive problem
By DJ_Bite in forum DVD & Blu-ray RecordersReplies: 12Last Post: 3rd Jan 2012, 12:19 -
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 14:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 11:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 13:01 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11
