everytime I want to capture a 6 hr tape, the audio is out of sync.
I think the video goes faster or the other way around.
please help
Probably some Noise in your tape, not the overall picture type noise, but the Noise such as a sudden jump in the tape, maybe a wrinkle in the physical tape [Everyone at some point has had an tape that was almost eaten only to save it, but you didn't really save it because the spot where you saved the tape was never the same again]
Some sudden wrinkle in the tape or major piece of noise in the tape threw off the DVC I MovieStar Software. No way around this, unless you can find the spot in your tape and figure how to record either without that piece of video or around it. Record up to that point and after or keep trying to record that piece untile MoveStar gets it right, but there's no way of knowing without stopping to play the clip because MovieStar doesn't display how many frames are dropped.
So basically your out of luck with a real solution, just the usual
What are you playing the files on?, if the clip plays out of sync on your computer then it's probably the above scenario. If it only plays out of sync on say your DVD player [just an assumption] then it could be your DVD player, some DVD players don't like the IPB setup [GOP structure] of Dazzle which records at I=1, P=9, B=2. The normal GOP structure should be I=1, P=4 or 5, B=2. If your DVD player is the problem then your either replace it or re-encode your video files after you captured them with an MPG encoder such as TMPGEnc or BBmpeg, etc.....Try Try and Try Again Routine
If you have to re-encode then it kind of defeats the purpose of recording real time MPEG's only then having to re-encode after the fact. -
I think its all tapes I use that are 6 hr long, at the audio is getting out of synch after like 5mins
Dazzle DVC 100 PROBLEM A valid input Signal has not been detected, HELP!
By Leon Smith in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2011, 15:14 -
Dazzle Video Creator Plus Help Please!
By FragpooL in forum Capturing and VCRReplies: 1Last Post: 24th Jun 2011, 00:51 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 10:42 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08 -
Dazzle DVC 170 PAL Problem - 'mirrored' screen
By Glaucous in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2007, 07:58
