When I play my vcd in my Panasonic ht-sa80 it reads and then stops at the time on disc. Im using Easy Cd Creator 5 Platinum and encoding with Tpmeg 2.54 on Memorex,Imation,and Maxell cdrw's. My buddy gave me some vcds using the same software and they work. But they go from the read to the time then displays vcd pbc then plays. I know my problem is in the burn process. Any help would be appreiciated, Ive tried the how to but they are based on the deluxe version not the platinum and are not the same. TIA
Results 1 to 1 of 1
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
How to burn DAO data disk
By logannsan in forum ComputerReplies: 4Last Post: 22nd Jun 2009, 13:17 -
Extracting Time Data from Mpeg2 Stream (Hard Disk Cam)
By gallion311 in forum Video ConversionReplies: 2Last Post: 1st Dec 2008, 10:55 -
Burn in Disk Utility
By andredanton in forum MacReplies: 4Last Post: 12th Feb 2008, 13:41 -
Burn AVI file to DVD disk
By clms in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2007, 15:10
