I've got a small problem with SpruceUp. I set about 20 chapter points in my video clip, adjusted each so it had a good "eyeframe", and had it generate a chapter menu, putting each eyeframe in a button. The menu it build looked good in editing mode, but when I ran the simulator, the buttons were faded (as if they were 80% transparent, although you did not see the background behind the button, it was just a faded image). The active button was a little less faded, maybe 50% transparent. I thought maybe it wouldn't look quite so bad after burning, so I gave it a shot. However, I got the same results--very faded, hard to see button images.
Anyone run across this problem before?
Results 1 to 1 of 1
Extracting menu buttons
By headless chicken in forum MacReplies: 0Last Post: 3rd Apr 2012, 00:54 -
Chapter list Menu problem with MultiAVCHD
By Jijital in forum Authoring (Blu-ray)Replies: 2Last Post: 23rd Feb 2012, 17:29 -
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 9th Aug 2008, 00:45 -
deleting menu buttons with pgcedit problem
By spiritgumm in forum Authoring (DVD)Replies: 5Last Post: 20th Apr 2008, 19:52 -
Menu Buttons looking odd
By TerryNG in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2007, 01:28
