  1. Ok I have this song but its a long version so I want to cut it so that the starting point and ending point is where I want it to be. What program should I use ?
  2. Try CDex it allows partial track recording and it's free:
    http://www.cdex.n3.net
  3. Um I don't have the song on a cd
  4. Member adam's Avatar
    Sep 2000
    If you don't need anything extremely professional like fade ins and outs then just use sound recorder. Chances are you already have it installed just look in Start/Programs/accessories/entertainment.
    Play it up to where you want it to start and goto edit/delete before current position. Go to where you want the end to be and hit edit/delete after current position. File/save as and your done.
  5. My File is mp3 not wav tho it won't open
  6. Use Nero.
    Load the tune up to record and right click then properties and you will see it all in there.
    Or use Cool Edit 2000.
    You will be able to do anything you want to it in there.
    Both will work for mp3.
  7. Member adam's Avatar
    Sep 2000
    So convert mp3 to wav, it takes about 5 secs with winamp.
