  1. I am creating all my showsin VCD in anticipation of getting a DVD player and need some help.
    My shows are currently in 5 chapters and need to know how to add a menu since I heard that some DVD's require a menu to have chapters work correctly.
    I run Linux and my current process of creating the VCD is
    vcdimager -l {insert appropriate label here} track*.mpg
    which gives me a videocd.bin and videocd.cue they work fine when I play them with "mplayer -vo xv videocd.bin" but then again mplayer is not as strict as a standalone DVD player.
    I DON'T want to install anymore software so I have to get it figured out with what I have
  2. Member DVO's Avatar
    Apr 2002
    Fire burner loads the .cue-file as a track list and use the .bin-file as sorce when burning the VCD. I dont know if Fire burner works for Linux.
