    Nov 2000
    Washington DC
    Hello,
    I am new at ripping DVD (~7gb) to DVDr (4.7gb). I followed the How To Rip guide on this site, but I am still confused. I ripped the entire DVD to my drive and used IFOedit to check what files are need. According to the guide, it tell my that I need titles 1,5, and 6. This should correspond to VTS_1, VTS_5,a nd VTS_6 files. However, the dvd contains files from VTS_01_01 to VTS_01_08. I tried using smartripper with the movie feature to rip only sectons for dvd to fit into a smaller DVDr. This is very different from the guide, where is is only few titles and 1 program chains. This DVD got only 1 Title, but tons of program chains (1 - 40).
    My questions is how can I fit all into smaller DVDr and retain the menu? any hints....
  2. Try...
    www.dvd2dvdr.com
    The method described here might be alittle easier to follow.
    If you have specifc questions after reading and following these steps then repost here & I'll assist however I can.
    D
    Nov 2000
    Washington DC
    I went dvd2dvdr and followed the instruction. I used smartripper to extract the correct vob files with ifo. I changed all output files to the same name. I used ReMPEG2 to encode the file.
    I downloaded SpruceUp 1.1 trial to create a menu. In the movie tab,, I right click to import the m2v file. However, an error keeps popping up when I select the m2v file (movie Tab) from the Spruce-It. The error msg states that
    "Temporal Reference in GOP #2387 (Zero-based_ are out of sequence (0xc10b000a)
    My guess, is that the file from smartripper or rempeg2 is not dvd compliant. If so, how can I make it compliant.
    What is this error and how can I fix and get to next and final step, which is to burn my first dvdr.
    Thanks,
    Rage
