I have been told that if I encode a vcd in the mpeg1 format at 23.97fps, I must add a 3:2 pulldown to convert it to 29.97fps. Alternatively I can encode the film (a dvd rip) at 29.97fps. Theory has it that if I encode at 23.97fps my standalone dvd player won't be able to play it or that the picture will be jerky. Now I have encoded most of my rips at 23.97fps because I notice a marked difference in quality compared to 29.97fps. I never add the 3:2 pulldown, and my vcds have always played with no problem. I have tried them on Apex players, a Sampo player, and a Daewoo player and each one has played without fail. So my question is, why must I encode a video at 29.97fps or add a pulldown to convert 23.97fps to 29.97fps? Am i getting bum information or am I missing something?
For a regular VCD (MPEG1), you do not need to add a 2:3 pulldown flag, in fact it's not even possible to my knowledge. A framerate of 23.976 is allowed by the VCD standard.
For SVCD, the advice is correct but not applicable to your situation. -
Thanks for clearing that up for me. Your answer was greatly appreciated!
If you can encode to NTSCFilm (23.976fps), you should -- you get more film per meg
Less Frames = Smaller File Size
and as kinneera said NTSCFilm is a VCD standardyour pal,
Stinky -
movie is at 23.97FPS
what if i used unlock.mcf template and adjusted the pixels higher... would that smooth or sharpen the picture?
24fps or 29.97fps ???
By RodNichols5 in forum Capturing and VCRReplies: 29Last Post: 27th May 2011, 18:26 -
25 or 29.97fps?
By pooksahib in forum Video ConversionReplies: 6Last Post: 16th Jan 2011, 17:54 -
Help with HD @ 29.97fps to DVD at 25fps
By Killer3737 in forum Video ConversionReplies: 9Last Post: 19th Nov 2009, 15:29 -
23.97fps to DVD
By El Duderino in forum Authoring (DVD)Replies: 2Last Post: 29th Jan 2009, 08:27 -
Converting 30fps to 29.97fps ?
By blewyn in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 11:24
