  1. On occasion I will find a DivX DVD rip that is very high quality and I decide I want to put it on DVD-R. When I am encoding the movie to MPEG2 I usually just set the bitrate as high as it can go and still fit on the DVD-R. However, I'm wondering if there is a certain point at which incresing the bitrate will no longer improve the quality. If I am right, how do I find out this magic number?
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    A lot of that depends of the quality of the original Divx file. All compression ratios will lose something, just through trial-and-error you can see exactly what ratio is best for you.
  3. Compression ratio? I just want to know how I can find out the point at which increasing the bitrate will no longer make the picture look any better.
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Originally Posted by tgpo
    trial-and-error
