I have a GOVIDEO DVD player that is vcd compatible but I don't think it is SVCD compatible. I burn SVCD movies that I captured with a DV camcorder and I can get them to play on my DVD player SOMETIMES. Is there a rhyme or reason it is playing SVCD's most of the time but some of my videos wont play at all? Can I flip some setting in TMPGEnc, my DVD player or VCDEasy to make my movies play consistently in my player?
Are you using a different brand of disc for the ones that wont play. Some players are fussy about the type of disc they will play.
Craig
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15 -
Can I copy & play from an incompatible DVD format to a compatible one?
By akersaz in forum MediaReplies: 8Last Post: 14th Mar 2008, 19:07 -
Which format is most compatible to play on other players?
By csmith in forum DVD & Blu-ray RecordersReplies: 9Last Post: 11th May 2007, 06:32
