Ok. How can i edit the video captured from my digital camera (it records on Digital Video Cassettes), and get it on to vhs?
-thanks
I hope your camcorder has the DV-IN enabled.
If your editing software allows you to export your timeline to tape, without having to create a new AVI file, what you can do is:
- connect the VCR to your camcorder's analog ports.
- play your timeline.
If your camcorder has the analog passthrough feature, you might have to turn this off first...I'm not so sure about this as my camcorder doesn't have this feature.
- record the video in your VCR.
If your software needs to create a new AVI first, then go ahead and render to a new AVI file. After that, you should be able to 'export video to tape', and again, do the connections/configuration mentioned above.
Or, you can export the timeline to your camcorder. Then connect the VCR to your camcorder, play the camcorder, record on the VCR.
hope this helps.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
