I hope I am posting this in the right group but my quesiton is as follows:
I am using TMPeng Plus to encode a raw avi I grabbed off of cable tv NTSC (US) feed using my Hauppauge card at a resolution of 480x480. When encoding what should I set the encode mode to on the Video tab and the source tab as when I want to create an SVCD? Interlaced or Non-Interlaced? Any help or information on this would be greatly appreciated.
Thanks,
Majunbubu
It depends on what you capture. If it's a movie choose do a inverse telecine to convert 30fps (60 fields p/ sec) to 24 fps and then encode with the 3:2 pulldown flag active) if you captured from a tv show a or somethin live etc... choose interlace to get the 60 fields. If you choose non interlace in these sources the motion won't be as smooth.
Thanks, I have been encoding in non-interlace and the motion looked like crap. There is one thing I am not clear on though. Should interlace then be selected (for grabbing live tv) on the advanced tab for Video source type then as well?
Thanks for you help. -
Since broadcast television is interlaced, and you grabbed both fields (480 vertical res), yes you want to choose interlaced for source.
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 03:33 -
Interlace or Bitrate ??
By garylanders in forum Authoring (DVD)Replies: 14Last Post: 4th Jan 2011, 06:14 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21 -
Interlace Question (I think....)
By pezpunk in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 11:20 -
Interlace confusion
By Bagshot in forum Capturing and VCRReplies: 7Last Post: 16th Feb 2008, 09:46
