im trying to encode movies with AC3 audio. after i encode it, the audio sounds like its under water. anyone know how to fix this? i use TMPGEnc
i tried using headac3he-0.23 like it says on the left. i go through the virtual bub instructions like it says. in headac3he when i try and load up the ac3 file it says "could not find data chunk". what does this mean? and when i try and start the encoding it says "not enough disk space". i have like 50gb free disk space. i dunno. big problems here. can anyone help me?
It sounds like you haven't renamed the wav file created with VirtualDub to .ac3. In this situation ignore the error about disk space afterwards, sounds like a bug.
Cheers
Nasdaq
Audio Player with stereo-to-AC3 encoding & user graph playback ?
By zamar27 in forum AudioReplies: 1Last Post: 11th Feb 2012, 17:21 -
What's the difference betwen AAC, AC3, and DTS audio's for movies?
By Eagleman in forum AudioReplies: 3Last Post: 29th Aug 2011, 13:36 -
Audio encoding AAC to AC3 for multiAVCHD authoring
By ejai in forum Authoring (Blu-ray)Replies: 6Last Post: 3rd Dec 2010, 11:00 -
MeGUI audio encoding dts/ac3 to aac-mp4, keep getting errors
By runLoganrun in forum AudioReplies: 5Last Post: 29th Jul 2010, 17:15 -
No Audio when encoding with AC3
By Stankia in forum AudioReplies: 2Last Post: 25th Apr 2008, 18:44
