Every time i encode a Divx to SVCD with TMpeg i get a series of 9 white small squares in the top right hand corner of the picture. They are arranged in a neat square 3*3. Although everything else in the conversion is smooth and my results are very good quality i just dont want these squares in the top right hand corner. Any helpfull suggestions ?
I remember reading about this issue but I cannot remember the source, The person has the exact same problem. If I remember correctly this person stated that the issue was related to the software player that was used to play the movie. He/she also stated that theSVCD played without any visual problems when played on a set top box.
Try using another software DVD player or see if it plays on your set top.
Hope this helps.
D -
I have found the problem, it was a MV2 codec that id downloaded, i now use one thats floating about on the net by Stinky i think. It works fine. As for the files i did convert using the older codec, they do indeed play faultlessly on standalones.
Srt File cannot display color expect white
By fantest in forum SubtitleReplies: 7Last Post: 30th Oct 2011, 17:24 -
tmpeg - no sound on output file
By greytop1 in forum Video ConversionReplies: 1Last Post: 3rd Mar 2011, 17:20 -
A font with only squares, how to create?
By sybariten in forum ComputerReplies: 3Last Post: 21st Feb 2008, 16:38 -
Squares Appear When Playing Online Games - Resolved
By HacktheHacker in forum Software PlayingReplies: 6Last Post: 20th Jan 2008, 17:07 -
Video file coming up white box on webpage
By KameronK in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2007, 09:24
